June 2011 - Phill's E30 V8 Tourer
Forum members' cars featured in magazines. Note - Before you can be included in this section you need to have an ACTIVE Journal of your build on this forum.
Postby Cam » Fri Jul 15, 2011 8:49 pm
Spec list as follows
E34 540 M60B40 non vanos
E34 530 5 speed transmission
Billet flywheel - Made by 2020 vision supplied by BBB
Helix 6 puk clutch
Mosler Cover plate
E36 328 Prop with a few modifications
E30 Med case diff 3.73 ratio
E30 drive shafts
Rawmotorsport manifolds
Ashley Exhaust system 2 x 2.5"
16" Pacet Electric Fan
E30.de engine mounts
Raw motorsport subframe spacers 20mm
E36 M3 Radiator
16 Row oil cooler
Power steering cooler
Correctly adapted loom
Full E36 M3 Evo front suspension and brakes - using HSD coilovers & topmounts
Raw motorsport lock spacers
E36 325 Steering rack (we had to box section the chassis to get the lock we wanted!!!)
E36 compact rear subframe, brakes and trailing arms
and a set of Rota Grids 9j x 17
Cobra Suzuka bucket seat
LMS 6 point harness
Full interior strip including sound deading
Hydro handbrake
Raw motorsport roll cage
LINK TO PROJECT THREAD
Cam
Admin
Return to Hall of Fame
Users browsing this forum: No registered users and 1 guest
